… is what I’m looking for.
So, displays based on TN or VA technology are out of the question.
Stuff like HDR and FreeSync/G-Sync can be ignored, refresh rate doesn’t matter.
Requirements:
- 100% sRGB and AdobeRGB color
- true 10 bit panel (not just 10bit compatible)
- 30" or bigger (no, 27" is not enough, because …)
- UHD or higher resolution
Suggestions, links to reviews, any information that helps…
I’d be thankful for.
Eizo CG319X covers 99% AdobeRGB.
Dell Ultrasharp UP321Q covers 99.5% AdobeRGB
Dell UltraSharp UP3218K ticks all boxes.
BenQ SW320 is at 99% AdobeRGB
No idea what the color spaces are the Sony BVM-X300 V2 supports, but it seems like it should do.
I can not make sense of what CIE1976 or DCI-P3 are, so no clue if the LG 32BL95U-W, LG 43-MU79-B or BenQ PD3220U would work for you.
Some of those look good, some are not really 10 bit. It is kinda tricky to nail that down sometimes. Especially with LG…
The Sony OLED and the Dell 8k are slightly over the top.
The Dell website was a good link though. I found the UP3216Q which basically does everything. And at a good price.
The BenQ SW320 seems to be on par but more expensive, mostly for the calibration stuff that I don’t need. (I’ve got the i1Display Pro)
So, I’ll keep an eye on the Dell.
Thanks.
risk
4
Look at an aggregator that has actual specs to filter on, like skinflint.co.uk , let us know which monitor looks ok to you
