hi all,
(Edit)
i'm about to buy a monitor for my build and i'm thinking in the Benq 24" Led Rl2455hm fits my needs but i also find the Benq Xl2420t 24" but is too expensive around $679 and in pesos thats too much, what do you think?
Benq 24" Led Rl2455HM
http://gaming.benq.com/gaming-monitor/rl2455hm
Benq 24" Xl2420T
http://gaming.benq.com/gaming-monitor/xl2420t
Thanks all
I'm kind of against anything bigger than 24 inch monitors, cause the bigger monitor you have the fewer pixels per inch you'll get and the image quality is reduced as a result as well as a larger part of the monitor will get further out in your peripheral vision so you'll be less likely to se (for example) an enemy in an fps game towards the corner of the screen. If your hardware is capable of running games at over 60 fps you might wanna invest in an 120hz monitor, it's such an incredible difference when you play games and 80 fps from 60 fps is already notable :)
If you wanna game you should get a monitor made for gaming. like an ASUS or BenQ monitor.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007617%2050001315%2050001583%204018%20600012673%20600416634&IsNodeId=1&name=23%20-%2024%20inches
there are a ton of monitor reviews and you'd be wise to research them before buying any monitor.
well i found the Benq 24 Led Rl2455hm here in mexico, i dont know if is a good one or notthat good, but from benq this is a good one in price and size for my needs :D what do you think (i'll edit the post)
i also found the Benq Xl2420t 24 but is too expensive around $679 and that in pesos is $6,865 pesos
wow that's crazy expensive :o i use an xl2420t myself and i'm quite happy with the 120hz and (as everyone says) it takes a bit of image settings tweaking to get the image right. From swedish currency mine cost 420 dollars, which is about the same price on newegg, so that 600 dollar+ is a ripoff :S
The reviews of the RL 2455hm monitor are good, and linustechtips unboxing <-- (You should watch) is quite positive and i think it's a good purchase if you're fine with a 60 hz monitor.
well, i saw the linus video and i'm happy with it, i think i'll buy it next tuesday, and see if they have some of the XL serie. and tell what happend :D, and well the problem here with the prices is that de goverment have this stupid idea that if came from another place that is no mexico they'll charge it with a ton of stuff ¬¬#
Yeah, i guess that's one way to enforce purchases within the borders :/
I'll look forwards to the followup!
