So I need to plug a new cheap monitor I have got for free that only has a VGA port, hence needing to put it in the motherboard ports. The problem is that it is not being detected. There is no Intel drivers in the driver menu, and only Nvidia drivers.
yeah righto the problem is, since it runs through VGA, ill need an adapter like you said, but I only have a vga dvi adapter, and my dvi are all taken up. is there any way around it?
Another thing to maybe notice, is when I go into the driver menu, there is an option for xorg, but when I select it, it won't use it, it will just revert to the regular one
