Monitor Assistance!
So far I'm gaming on a Samsung TV I want to say around 32 inch, and I always get told how bad they are compared to monitors. Well...I was told once anyway. So I was looking into grabbing a gaming monitor that looks pretty good too. Would like for it to be 1080p please.
Thanks!
Budget?
You want an ips panel btw
How much would I have to spend for a good one?
nah. really, unless you have a high budget, TN is just fine
get an asus 23". ~$130
Happen to have a specific model in mind? :P
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
Thanks! The guy up above mentioned something about IPS monitors..? Should I look into that or just stick with what you've provided me with.
Crimson, here is a comparable IPS panel for the same price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009483
Whats the Main difference between IPS and LCD or LED or whatever? I'm not monitor savy. Thanks for the link.
