Monitor advice
Hello, I am seeking advice on purchasing a new monitor. I have nystagmus, which causes involuntary eye movement, along with a visual impairment—20/30 in my left eye and 20/60 in my right eye. I am currently pursuing an online Bachelor of Science in Applied Artificial Intelligence at the University of Tennessee, Knoxville, and I’m a bit unsure about which monitor would be best for my needs. I currently own a 27-inch flat LG OLED monitor, which I plan to use as a secondary screen oriented vertically for assignment documentation. For my primary monitor, I am trying to decide between a flat 32-inch QD-OLED or a curved 34-inch QD-OLED. Regarding the curvature, I would appreciate guidance on whether a 1000R, 1500R, or 1800R curve would be better suited for my eye condition compared to a flat display, before I make a purchase."
Can’t really help with the eye specific stuff. Just wanted to mention that it’s rarely a bad idea to try matching the pixel pitch between monitors. Depending on OS scaling between screens can be a pain.
Mate, you have some very specific needs. Really, you’d need an optometrist to answer those specific questions, especially for not exacerbating your existing conditions.
But, if I may suggest, your best bet to find the right screen for you is to go shopping. Hit your local retailers and wander past the screens they have set up.
I dare say your own eyes will answer questions the spec sheets won’t. Even if you don’t find ‘the one’, the panel types and curvatures you’re after may prove very obvious.
Screens are so subjective, I say the same thing every time I get asked.
This is not something to overlook. My current setup is 3 27” 2K Monitors that are identical. I have two stacked horizontally and one on the side vertical. Compared to my previous setup (x1 27” 2k , x2 24” HD, same layout) it is a huge difference. Being able to move a window between monitors and the window staying the same size is amazing, also the color is the same on all of the monitors.
I personally hate my main monitor for having a curve. Means there is exactly one position to sit in, and if that gives any weird reflection, you are SOL.
Go flat.
