Monitor advice 42"+
Hello all.
First time here .
My question for you all is this:
For the moment I have as my main monitor LG 34GN850-B and a ViewSonic 2K. I am using them for Gaming and Coding.
I am looking for a single 4k monitor upgrade.
So far I found the following monitors and tv’s:
  • Gigabyte AORUS FO48U
  • LG C2
  • LG 48GQ900-B
  • ASUS ROG Swift PG42UQ
  • Samsung neo G9
Any feedback will be greatly appreciated.
Have a Happy New Year with lower prices at tech.
Thanks and take care!
is this used for couch gaming or at a desk
because as a user of 50 and 42 inch TVs as desk monitors, just get a smaller one thats closer
Desk.
Want to switch from a multi monitor setup for work to only one that i can use it for gaming.
And also to a 4k.
Thanks
well, TVs are cheap, monitors are expensive
check out both see what checks off all your boxes that you want and need
TVs don’t usually have G/Free Sync but modern ones have HDR
watch reviews before you buy
that’s all I got
Thanks for the help.
