so i want to get the xfx double D 7850 and i have a xfx 450 powersupply. my issue is my Psu only has 1 6 pin and that card requires 2. i have 3 open molex on my rig and i want to know if its saft to get a molex to 6pin. i would really like to not have to buy another Psu. i heard they put out the same power as a 6 pin, just diffrent kind of addaptor. i also see that some Gpu come with the addaptor, so i want to know it its safe.
I dont think it is safe to run 2 7850s on a 450 watt power supply. You could go with one 7870 though. it wont be as strong but you will save a lot of money and you wont have to upgrade your power supply.
