I was given a modular power supply from a friend who recent upgraded his computer, unfortunately his pcie cable was missing. Now I've scoured the internet to find a new one and I can't find one that is a for sure replacement.
this is my power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153059
Now I can't find the cable layout for the pcie and I'm thinking about buying this as it looks very similar
http://www.ebay.com/itm/21-Black-Braided-6-Pin-to-6-Pin-PCI-E-Cable-For-Modular-Power-Supply-/231257349658?pt=PCA_UPS&hash=item35d8031e1a
Maybe someone here knows the cable layout and can verify this will work or can at least point me in the right direction
Why not use a molex adaptor?
I am using the molex to power something else in my system and do not want to overload it
a 6 to 6 wont work as the connector is actually not same as a 6 pin unless you are willing to cut it in to individual wires and rearrange. pop open the inside, look at back of connector, it will say gnd (black) or +12(yellow) wire custom connector from that knowledge
also that psu will catch fire.
dont trust it for maybe more than 300w
http://www.moddiy.com/products/6%252dPin-PSU-Modular-Power-Cable-to-PCI%252dE-%2830cm%29.html
how about this then?
Should be fine, but in all honesty that psu is really bad. Like to the point of what did you do to your friend for him to give you a fire hazard.
Well if I sent you a link to the power supply I have now you'd think it would make my computer to explode, but to the point I just need a higher wattage psu because I'm upgrading to a 8320 soon and my 400w psu won't cut it. If you have and other suggestions for a psu than link it, but if it's like 100$ I'm gonna pass
