Using my Radeon VII daily with LLMs, I figure I’ll make a single source of model performance on my workstation.
5950X
64GBRAM
RVII
llama-swap
my own harness
Ubuntu 24.04 ESR
kernel: 6.14.0-37-generic
I frequently test new quantizations and finetunes. I try to keep models busy as often as possible mostly on coding verification and documentation currently.
The test for this run is: osc/registry/productivity/home-inventory.osc.md at 4ce739037c1c3dd9c7394be05d82fcfb4a64f085 · s1ugh34d/osc · GitHub
The prompt is only the OSC raw data. I use 0.7 temp in the prompts, and although many of the models write code, the software is far from complete in each first one-shot.
I haven’t tuned out the build to where I can upload snapshots to OSC datasets yet, but the one-shot contracted software I find gives me a feel for the performance a given trained weights will have for my workflow.
| Model | Cached Prompt Tokens | New Prompt Tokens | Generated Tokens | Prompt Speed | Generation Speed | Duration |
| gemma4-e4b-opus | - | 1,034 | 1,948 | 1,199.50 t/s | 76.59 t/s | 36.55 s |
| qwen3.5-9b-deepseek-v4-flash | - | 1,015 | 1,204 | 810.67 t/s | 66.20 t/s | 29.70 s |
| gemma-4-12b-coder-fable5 | - | 1,035 | 2,756 | 541.56 t/s | 44.92 t/s | 73.53 s |
| deepseek-r1-0528-qwen3-8b | - | 981 | 15,403 | 837.05 t/s | 62.73 t/s | 256.97 s |
| qwen3.6-14b-a3b-fablevibes | - | 1,015 | 4,959 | 1,144.87 t/s | 72.23 t/s | 69.54 s |
For the plaintext data^
