So i've got no idea what to look for when it comes to motherboards, and i'm completely lost. i did some research on a store and decided that this cpu would best fit me, but i don't know what mobo would be best.
Pretty much your only option unless you can source an OC formula which you WOULD NOT be disappointed.. its an OC BEAST... that or the extreme 6 which is a very awesome board. The asus has a nice UEFI that or the giga g1 gaming. AVOID MSI like the plague...
I've got an MSI Z97s Krait edition, the board works fine, I've had no issues since I bought it.
They cheap out on the little things though- the IO panel is pretty poor, there was no SLI bridge included, which seemed odd being that it's marketed specifically as an SLI board.
I've had a 4690k overclocked at 4.2 on air since I built it.
If I had the choice again though, I'd probably go with a Gigabyte board. I was really impressed with the G1 Gaming GPUs, so would like to think the same quality would be in the motherboards.
