I'm buying the AsRock Z77 Extreme4 motherboard and the NZXT Phantom case. I'd like to know do I plug the case fans into the motherboard or the power supply? If I do need to plug them into the psu is a different connection used? Do I need to get an adapter of some sort or will it work with the 4-pin connector? (btw I'm using a modular power supply if that makes a difference).
I'm a first-time builder who wants to be sure of absolutely everything before I even start.
Thanks a lot in advance guys! :)
