Hey i'm using an fx-4300 and want the ability to put in 1600 mhz RAM in the mobo (not buying 1333 RAM and OC it to 1600) does anyone have any suggestions for an am3+ mobo with atleast the ability to put 1600mhz RAM in it around 50-55 bux? Thanks!
All AM3+ motherboards support it because the memory controller is actually integrated inside the CPU. The integrated controller supports up to 1866 natively.
Looks like it should be Fine.
tanks
