Hi, I plan on building an AMD system, and I want to get the Asus Crosshair Formula-z board but I also want the Asus Direct Cu 2 7970 card which is a triple slot card, wondering the mobo has room for this card in crossfire?
You would have to place one of the graphics cards in the 3rd PCI-e x16 slot down and it would run at x16/x8 speed instead of x16/x16 if you were to occupy the top two slots. I would really rather suggest you go with a pair of the MSI Twinfrozer dual slot HD 7970 or HIS IceQ X2 dual slot HD 7970 instead. The Asus DCII v2 HD 7970 is an excellent card but it was designed more for single GPU configuration with how bulky its cooler is.
The Gigabyte UD7 is an example of a board that you could put that card into in crossfire.
The first PCI-E slot is X16 and then there are 3 more slots before the second X16.
Hope that helps! I haven't used this board but here are some reviews!
