I this motherboard http://www.newegg.ca/Product/Product.aspx?Item=13-157-506 compatible with my AMD FX-8150 cpu? And is it compatible to overclock with that cpu?
Nope, it is not compatible.
Anything on this list is compatible with the AMD FX-8150 though:
http://pcpartpicker.com/parts/motherboard/#s=4,22&sort=d5
I would suggest the ASUS M5A99FX Pro R2.0 or the ASUS M5A99FX Evo R2.0. Both can overclock.
really not sure if this is a troll thread or what.....
OP amd and intel cpu's aren't cross compatible. Hence separate listings for each other - amd am3, fm2 etc /// intel z97, intet h87, intel 2011 etc.
Its not, I'm just a noob when it comes to motherboards entirely, thanks for explaining it though :P
One of the main reasons I was upgrading was so I could get usb 3.0. Do you know any decent around 100-150 dollars with usb 3.0?
Awkward I meant to say pci express 3.0 ports, but I am watching a video that said amd mobo's all run 2.0.
Those asus boards (mentioned above) are excellent value for money & have onboard usb3 headers - this is what you plug the internal (blue tip) cable to thats inside your case.
good solid Asus boards ... there are more expensive ... but these will hack it.
- tell us what you want
- what you want it to do
- and a budget ..... we will give free advice and opinions ... most of it good ... ;lol
I don't even think Titans fully saturate PCIe 2.0 slots, so you probably won't need PCIe 3.0 slots. Although I think certain some boards on the FM2+ socket have PCIe 3.0, but that won't work with an FX 8150 either.
http://www.techpowerup.com/reviews/NVIDIA/GTX_980_PCI-Express_Scaling/
interesting read
Watch this.It will answer most of your questions.
https://www.youtube.com/watch?v=ZnaQyGAg8Eg&list=UUkWQ0gDrqOCarmUKmppD7GQ
When looking for a motherboard, you start with the right socket. When your CPU is an FX-8150, your socket is AM3+, so only AM3+-Mobo will work. The board you suggested in you OP is a socket 1150-Mobo, which is intended for Intel-CPUs.
Yeah I heard it doesn't even really make much difference, but thankyou for the help! probably going with the first one you recommended!
