Mobo Choice Help
I don't know much about motherboard brands and I want a good one for my new build.
I'm getting an i7 4790k, so I need socket LGA 1150. I'm getting a GTX g1 gaming 970, so I want two PCI Express x16 slots, in case I later decide to upgrade to SLI. It would be cool if it had blue or black colouring because that is the scheme of my other parts, looking at the 100-150$ range canadian, although with the dollar crashing I'm not sure what I can get.
I think that is it but in case you need it I will link my PSU and case, all recommendations are much appreciated :)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151138
http://www.phanteks.com/enthoo-pro.html
This is the cheapest SLI capable blue/black motherboard it seems: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130775
On further search it looks like it may be one of the few SLI capable motherboards in that budget.
Yeah i was also on the hunt for OP.
Black/blue
  1. Asrock Z97 Extreme 3
  2. Msi Z97 Sli plus.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157506
Thankyou guys so much for the help, I decided to go with the msi, hopefully I made the right choice!
