Mobo and this CPU, will it work?
Hey guys, i am kinda on a hunt for an upgrade on my PC.  So i came to the decision of the fx-8350 after a decent amount of research.  My question is will my current motherboard work with this cpu?  I do plan on upgrading the motherboard in a month or so after i buy the cpu (if i do) once i get the money.  Ok so thank u everyone and here is the mobo that i have right now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
I really don't recommend 970 chipsets for 8350 CPU as they are very power hungry, especially if you overclock them. You will want a superior power phase design instead of the 4+1 you will get on this board. I would recommend a Asus M5A99X Evo r2.0 as it comes with a 6+2+2 powerphase, which will give you a nice, stable overclock. Along with keeping you components cool and increasing their longevity. If that is to high from you budget, the only 970  board I would recommend in the Asus M5A97 r2.0 as it does come with a 4+2, but the quality of parts used will help sustain a decent overclock, unlike other 970 boards.
Do u think i will atleast be able to run the 8350 on my current motherboard for a month or so, with no overclock?
well be a bit carefull with this, you can offcourse run it for a month but dont overclock, and enable, all power saving options. so that the vrm´s are not constantly under full load.
I would recommend to turn things arround buy a new / better mobo now, and the FX8350 the next month. trowing your current cpu on a better mobo, can never hurt. otherway arround the FX8350 on that msi board can hurt. just my opinnion ☺
It also saves you alot of work, wenn you buy your new cpu, next month, you only have to change the cpu then, not the complete motherboard, thats less work!!
Base Level... Yes
