I have an old girl we are trying to get going as a test environment to train people up in. The system will install Windows Server 16 fine. When I boot the machine it will not make it to the login screen with the Smart Array P420i Controller enabled in the bios it stalls on the Windows splash screen with the rotating dots.
If I disable the controller the OS boots fine on the SATA SSD. Problem is when the Storage Controller is disabled it will not install the drivers.
Barks at me "The software will not be installed on this system because the required hardware is not present in the system or the software/firmware doesn’t apply to this system. "
Lastly, I know the controller is good, I have been running a Linux based OS off the raid for almost a year before we decided to make this change.
Is there a way to force the drivers to install without the device on? Or sideload the drivers? I just need this machine to make it into Windows Reliably with the raid enabled.
Talked with a colleague and they have 2016 running on G7 hardware, so G8 should be no probs right!?
For your firmware, download the latest SPP, boot it directly and let it do it’s thing. You likely need an ILO upgrade to fix that bad url error. They keep fiddling with both the built in url, and I think TLS.
Well, I just am now getting back to updating this post.
Things I have attempted
Updated the iLO firmware to the latest version, still can not successfully use the HP tool built into the machine
Download the SPP and gave that a go, would not boot, maybe a bad SPP so I am not totally finished exploring this option
Tried installing Windows 2012 R2, the same lockup occurs when the windows banner flag is up and the circles are forming.
I am pretty much out of ideas about what I could do next to get this machine on a Windows Platform and retain the raid functionality.
Again Windows Server 16 and Windows 2012 R2 both function fine without the raid enabled.
I guess I am going to take the machine back to Linux until I find a solution for this, so frustrating not being able to get around the HP Paywall to use a very expensive piece of gear albeit old. Especially since this machine is listed to be supported by both R2 and 16.
Are you using Intelligent Provisioning to install the OS?
When you say that the SPP wouldn’t boot, did you use a USB 3 or USB 2 thumb drive? I believe USB 2 is the recommended method. Trying to boot it from inside ILO might not work either.
If you can boot the OS with the raid card pulled, you can run SPP that way as well.
Okay, it was a USB 3.0 its all I had in the shop, I’ll have to dig up one of the older drives.
Used Rufus to put the SPP on a USB and then booted straight from the USB, hit a linux prompt with a “Failure to boot”.
The install that is on the box atm is Windows 2012R2 which I used a USB to install. I tried using the Intelligent Provisioning to install once as well, it did not like the bootable media I had in. Is it looking for an ISO?
I can see why my entire shop moved over to Dell and handed this to me (the new guy). What a nightmare.
I.P. wants the ISO unpacked onto a USB thumb drive, I would use USB 2.0 to be safe. Rufus should do the job.
Burning the SPP to a USB should work. Make sure you select MBR as the boot option in Rufus, if I’m recalling that correctly.
My shop is 90% HP, with two Dell in the mix. I find the HP a lot easier to manage, not a fan of Dell’s iDRAC solution. But I’ve been drinking the HP koolaide for more than a decade so kinda grown comfortable with it I suppose.
