I'm doing a build very similar to the caluga (or whatever it's called) same case anyway, and I'm worried about heat in the case, what 120mm fan would you recommend for food airflow and noise? Why? What heatsink would you recommend? The Noctua Logan used?
nzxt fans are cheap and almost as quiet as noctua
theres a cooler master closed loop on sale that would work well with a nice noctua or nzxt fan.
Really depends on the case that you're going to get. The Noctua NH-L9i is a great low profile cooler. It's performance is only a little bit better compared to the stock cooler, but it's a lot quieter.
I have the Seidon 120V in my Fractal Design Node 304. I'm able to mount a radiator because of the design of the Node 304.
Since you're using the little lian-li case, I would just stick with a noctua NH-L9i if you cared about the noise. I find the stock coolers not as bad as people claim them to be, though.
