mITX $2000 Build Help
Hello guys and girls, I wish to make a BitFenix Prodigy build for on the go gaming for lan parties and just going to friends places. My budget is $2000, I have the Monitor, DVD Burner and Windows 7 so no need to add those in, I wish a 250GB or over SSD and must be in a BitFenix Prodigy. I will be mainly usiong this for gaming and I was hoping this would last about a year without any upgrades.
My Build so Far:
http://pcpartpicker.com/p/UE2p
http://pcpartpicker.com/p/UEbZ
Managed to shove a Titan in there :)
I was considering a Prodigy a few months back when I built my Lan Box. If the only reason you are interested in that case is because of it's "mobility", you should look into the CM Half-XB lanbox. Dimensions are slightly shorter and wider. Prodigy = 9.84"W x 15.91" x 14.13", Haf XB =17.4" x 13" x 16.7". The half xb will allow you to use an ATX motherboard and therfore more options in general. Just an idea.
bitfinix is overrated hipster case
