Hello,
I find myself in a bit of a pickle. I recently bought a second M.2 SSD but while my motherboard (ASRock x370 Taichi) has a second slot, this slot is missing a spacer.
As you can see, not only is it missing a spacer but also the copper-colored nuts which are present in slot 1. The board did come with a second m.2 screw, for whatever good that does me.
According to the Manual, both slots should be equipped with the same nuts & spacer.
The board is already over 2 years old, so I don’t know if there is any use in trying to contact ASRock support, so does anyone here have any advice on how to work around this issue?
