So I got a beta key for Mirrors Edge Catalyst and here are my benchmarks.
Build: http://valid.x86.fr/09klg6 (I reduced most of my OCs for the test)
Running Windows 10 Enterprise N 2015 LTSB
CPU hovered at 4013 MHz
GPU Core: 1538:
GPU Memory: 3703
GPU Shader: 3075
Test were conducted at 1080P. FRAPS recorded frame rate.
Core Test (Cores added sequentially)
Tested looking at a blank wall on Medium over a period of 30s
Num of cores | AVG fps | Total CPU Usage | GPU Usage (Core)
1 | 10 | 15 | 10
2 | 15 | 25 | 15
3 | 45 | 40 | 27
4 | 84 | 50 | 52
5 | 120 | 62 | 74
6 | 126 | 66 | 78
7 | 130 | 68 | 80
8 | 133 | 66 | 82
Under 3 cores the FPS was very sporadic. RIP the dual core dream?
Play through Benchmarks
Recorded over 5 min each
Free roaming in Concord Plaza on Medium
Frames: 22928 - Time: 300000ms - Avg: 76.427 - Min: 56 - Max: 104
Opening Mission (first 5 min after cutscenes) on Medium
Frames: 28212 - Time: 300000ms - Avg: 94.040 - Min: 59 - Max: 122
Opening Mission (first 5 min after cutscenes) on Ultra
Frames: 22089 - Time: 300000ms - Avg: 73.630 - Min: 48 - Max: 106
Notes
-Opening mission is at night with light rain
-Runs DX 11
-I see support flags for Eyefinity in API Monitor 2
-Let me know if anyone wants a test from an AMD card (Radeon HD 5850 or A4 4000 APU)
Photos of Menus
<img src="/uploads/default/original/3X/2/c/2c73c7f38f92fe02092399108c96f3c223686584.jpg" width="720" height="405"
