Whats the best micro atx motherboard for a new build using an fx6300 and r9 280x to fit in my existing fractal core 1000?
Thanks
Thanks
All of the mATX motherboards for am3+ sockets are shit.
ok, is there no option....i want to keep the size down and use my fractal case? what about a temporary option for possible upgrade later?
Probably this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131942&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
and I say that because it has USB 3.0. You just won't be able to overclock really at all.
thanks....might do for time being
FX6300 90W tpd on those boards, should be fine ☺
no not really, http://www.asus.com/Motherboards/M5A78LMUSB3/
this one does pretty good my freind. if your forced to go micro and you dont have alot of dollars this board will sopport!
