Mionix Propus 380?
So I decided that since I had a high quality keyboard, I may as well have a high quality mouse pad. I ended up going with the Mionix Propus 380. I love this mousepad. I really do. But it doesn't work. when moving the mouse side to side on the pad, it works fine, but if I move "up and down" on the pad, it's like it gets "stuck". The cursor moves, then stops moving for a bit, then moves again. I was using a mouse pad from the Collectors Edition of Wow, and it works just fine on that.
I'm using a Razer Naga Epic which is a laser mouse. On the Mionix website, it says the Propus 380 is for laser and optical. Has anyone had any similar experiences?  Help!!
