After a simple reboot after lutris wouldn’t start my computer dumped me at the login screen and whenever I login the screen goes black and then it goes back to the login screen any help would be great. Sorry if this the wrong place to post this and I’d so could you tell me where to properly post this.
(edit) I’m running r3 2200g rx580 and I get to the gui but I can’t access a functioning command Line
nvidia card? can you get to grub?
If so could try the nomodeset=0 thing or the nouveau one. usually not an issue nowadays, but might be the cause (you may want to tell people what exactly you are running ie hardware, version etc):
Solved
I had to boot into recover go into root and delete some unneeded stuff to allow it to boot and now it works fine
