I have a Minisforum MS-A1 with a Ryzen 8700G and 64 GB 5200 MHz RAM.
I mostly run this as a desktop PC and sometimes KVM (not in connection to the issue I’m asking about).
When the device sleeps, either manually or by sleep timer it will on occasion lock up and the chassis gets toasty hot. At this point nothing but a hard reset helps, device is not on the network or in any other way responsive. I’d say this lock/freeze happens around 25 % of the time.
Journalctl does not log any issues as the devices goes to sleep and the next entries are after the hard reset.
Jan 04 00:40:42 min01 systemd-sleep[201673]: Entering sleep state 'suspend'...
Jan 04 00:40:42 min01 systemd[1]: Starting systemd-suspend.service - System Suspend...
If any other details might be relevant let me know.
I guess not letting it go to sleep might be an option but since I mostly use it as a desktop I think it makes sense to let it suspend.
Other than that it’s vanilla Debian 12 as for the kernel parameters or anything affecting hardware. Secure boot is on. One thing I do is run displayport passthrough over displayport so I could hook up separate cables for this maybe?
uname -r
6.1.0-28-amd64
