Minimum Power Requirements/PCIe Bottlenecks For HD 7770
A not so computer literate friend of mine wants to buy my old 7770 off of me to put in his prebuilt HP Desktop PC.  my problems is that I don't know how much power is needed for his other computer components+ the graphics card.  He currently has an I3 and 12gb of ram.  I don't know his other specs but I do know that if his power supply isn't good enough, I can sell him my old CX430.  I know 430 will be enough for his system but I don't know if what he has is good enough.  I also know that the power requirements posted by the 1st party people are generally overkill,  So I'm asking what the minimum will be.
My other question is whether or not it will be worth it to upgrade his system.  He is currently using the integrated graphics so I know it will be a good boost, but the problem is that I don't know what version of PCIe his MoBo supports IF it even supports PCIe.  So I'm basically asking if It's worth it to upgrade if the PCIe isn't current  gen.
TL;DR:
How much power does my friend need for a new(To his sysmtem) GPU?  Will a new GPU be a help if his MoBo only supports last gen PCIe?
Thanks
430w is plenty for a 7770 and his rig.  I wouldn't rely on the PSU that comes with his prebuilt PC though, as it probably doesn't even have the PCIe power connectors and probably only has enough wattage to just barely support his computer specs.
Just check his case/mobo to see if you can upgrade it.
Sell him the 7770 along with the CX430.
Open up his case and find the MB make and model. It'll probably be printed directly on the MB somewhere. Google that and you'll be able to find all the specs. That'll tell you which version PCIe he has. As long as there is a PCIe x16 slot, it would be a pretty sure bet to say that your 7770 will improve his graphics. If there isn't a PCIe x16 slot, obviously it won't work and your problem solves itself.
In short, Some Tech Noob is probably right. Find out if the card and the power supply fit, then sell him the 7770 and CX430.
Agreed with above... gotta know specs... chances are it's the biggest POS Biostar mobo they sell that will supprt his i3 and a random company PSU with 300w... the draw from a 7770 isn't overkill so with a CX430 it's not a big stretch it should be fine... it's not like you're selling him a 780 or r9 290
Alright.  Just as a bonus question, what do you think would be a fair price for both of them?  They have been used for less than a year.
Well, the 7770 can be gotten for 90 bucks new after a MIR, and the Cx430 is 25 after another MIR.
I'd say somewhere between 70 - 100 bucks, depending if you want to be nice or suck money out of your friend.
