Mini-ITX motherbord 1155 socket?
Can anybody recommend an ITX motherboard that supports 1155 socket and perferably has WIFI built in to it?
Thanks in advance!
Asus P8Z77-I Deluxe
+1 good choice, if you can still find one.
THat particular board has atleast a decent vreg design.
Thanks for the answer but I seems like I can't find one from a reliable place here in Sweden but i think i might be able to buy a pretty new CPU with a newer socket type from a friend.
If you know of another good ITX motherboard, please post it.
Well if by newer you mean LGA 1150 then I'd recommend the Asus Z87I Deluxe. Basically the same board but new socket.
depending a bit on your budget.
If you realy want a top notch Z97 itx board, for overclocking and what not, then something like the Asus Maximus VII Impact is the board i would recommend, But yeah its expensive.
Some cheaper alternatives.
  • Asus Z97i plus
  • Msi Z97i Gaming AC
Thanks for the help but i'm just gonna upgrade to a new CPU instead.
Probably the best choice. I looked for an 1155 ITX motherboard like a month ago and couldn't find anything other than some H77 boards that were overpriced in my opinion.
