Mini itx motherboard help
i am building a mini itx pc and i was wondering if there is any performance differnces between the B75, H61, H77 or Z77 since the price between them is so drastically different. i dont mind having less features on the lower end chipsets just if there in any in game performance differences.
okay H61 is low tier, it has sata II, only CPU overclocking options, you can't change ram speed or timings, which means you might be stuck with 1066 or 1333 ram, B75 is the same way EXCEPT it has SATA III and some other nicer features, overclocking is still the same as H61
as for z75 and z77, the have ALL overclocking features letting you choose up to 2600 ram speed
