so i want to make my current pc into a mini itx i have questions about my psu and gpu and weither all my stuff will fit obviosly i need a new motherboard my current gpu is a 7950 gigabyte its 27cm in length my gpu is a http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051 im not very sure about the sizing info on that but all i need to know is what case i should get that could fit al this i want it to be small as possible i really like the lian li cases but not sure if they fit what i have and if you guys have any recommendations on motherboards too thanks alot
btw sorry for my shit spelling
It says in the desciption that it supports GPU's up to 30cm's in length and standard PSU's...
You'll be fine.
standard Mini-ITX motherboard, standard 5.25" optical drive, standard 3.5" hard drives, standard ATX PS/2 power supply units and long graphics card.
I recommend the 550W XFX, it's a rebranded Seasonic. You don't need 750W in a mITX build, and the CX series from Corsair isn't great.
It states that long GPUs will fit. I would recommend the MSI Twin Frozr 7950. It's a nice sized card, good quality.
Woops! Can you tell it is late here?
You've bought those components already. Yeah, they will both fit
thanks guys im dumb as shit so i wanted to be safe
