Mini-ITX CPU Cooling?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811205011
I'm going to be building a computer in this case and I don't really know where to start for a good CPU cooler.. I've probably looked at every low profile cooler but none of them seemed like they would do any better than a stock Intel cooler.. (Going to be getting an i7-4770k by the way)
Anyone have any suggestions?
Here are the limitations of the case for cpu coolers.  http://www.evga.com/support/faq/afmmain.aspx?faqid=59439
I'd say something like the NH-U9B SE2 would be the best pick, it fits, has duel 92mm Noctua fans and is fairly thick with four direct contact heat pipes. These make it one of Noctua's quietest coolers (making it near silent, only about 18dba) and it should cool a i7 really well, even with a slight overclock, however your not going to be pushing the sorts of numbers you'd get with a massive cooler like the Noctua NH-D14 or a 240+mm AIO cooler, especially in such a small case.
Best thing is the NH-U9B SE2 is worth less than $50 in the states, so if you get another cooler and add a second fan your going to pay most of that anyway. Another bonus is its light enough not to put much stress on your motherboard, particularly because Noctua's mounting brackets are very solid and well made, I'd say some of the best around.
By the way, I'm not really a Noctua fanboy here, I personally think there fans are overpriced, even considering the bunch of extra accessories they include, which are good. I'm also normally a fan of AIO coolers over large air coolers, however since you chosen case doesn't support AIO coolers or large cheap coolers (I'm looking at you hyper212evo) the Noctua NH-U9B SE2 is certainly the pick of the bunch.
Now if looks are super important to you (unlike me, personally I don't really care about appearance) then the NH-U9B SE2 probably not ideal for you. Having said that you can probably swap its extremely good but horrid looking 92mm fans with something to match you build fairly easily, fixing this issue, but that removes 9/10ths of why the cooler is both silent, cools well and is such good value, and will of course the new fans will cost you extra, just to sweeten the deal even more.
Wow. o.o.
Thanks a bunch!
