Ok so I am going to be building a mini-ITX build and I want it to be super compact. I already have a 7200 rpm seagate barracuda 320gb hard drive and a EVGA Nvidia GTX 650 ti 2gb SSC card so that's all good. Here is the parts I have picked out and just so you know my budget is $450 tops for everything so if you have any other recommendations let me know.
CPU- AMD A10-5700 http://www.newegg.com/Product/Product.aspx?Item=N82E16819113289
PSU- Seasonic SS-E350ET Bronze 80 plus certified 350 watt http://www.newegg.com/Product/Product.aspx?Item=N82E16817151077
RAM- Avexir Core Series DDR3 1866 8gb (2x4) http://www.newegg.com/Product/Product.aspx?Item=9SIA0ST08P6216
DVD Drive- Samsung USB 3.0 Slim External http://www.newegg.com/Product/Product.aspx?Item=N82E16827151262
Motherboard- Asrock FM2A75M-ITX http://www.newegg.com/Product/Product.aspx?Item=N82E16813157363
Case (I DO NOT WANT TO CHANGE THIS DUE TO IT'S SIZE)- DIYPC V3Plus-B Black Mini-ITX Tower http://www.newegg.com/Product/Product.aspx?Item=N82E16811353014
