As some of you may know, if you've seen my previous posts, I keep mentioning my next build being a mini ITX form factor build, simply due to the lack of physical room I have. Anyway, I just wanted to ask, is there an elegant solution to using both a mini ITX case and 3.5" drives, I was thinking about something as small as possible like the RVZ02/RVZ01-E by Silverstone. Now I know neither of those cases support the use of a 3.5" HDD, so I thought maybe I could buy enclosures for the drives, and have them outside of the case. However, I'd still like to maintain the best possible performance, so I was wondering, is there a nice, neat, and simple way of connecting the HDD(s), via SATA, external to the case? Or would you guys say this is a terrible idea? Maybe I should just consider getting a 2.5" HDD instead, to work alongside an SSD? Or even better, would I just be better off using the RVZ01 (none -'-e' version), as that case does support at least 1 3.5" drive? Then maybe use one external HDD connected via USB3.0 or something along those lines?
Finally, can any of you guys suggest good cooling solutions for such a case? Are there any AIO liquid coolers that would definitely fit within such a small space? - I've seen some images, and a video or two, but they don't paint a concrete image/idea. Also, just to note, for cooling, I don't need anything too amazing, as I'm not the kinda gamer that's so hardcore that they demand every FPS they can possibly get, I'm happy as long as it's somewhat playable, 60 is great, I don't need more than 60, 30 is okay, I can live with it to say the very least. I don't play a tonne of demanding games, and I'm not the kinda user that requires anything too crazy or intense, so that's all the more reason why I'm thinking about going for the mini ITX form factor, I don't need all of the space and pros that you get with a midi tower case. The only benefit that I get with a midi tower case or bigger is that it'll be easier to keep my components cooler, other than that, there's not much else, other than that, there are only disadvantages, considering I have a serious lack of space for my setup.
Anyway, I'd appreciate any replies or responses, thank you guys.
FINALLY. To anyone that's read previous posts from me on a similar subject, I do apologise, I know I've been somewhat annoying to try and cater for on such a subject, but I do appreciate previous feedback, and I do appreciate you trying to help me out. So again, thank you guys! :)
