I need to host a minecraft server for my brothers, and I can't pay some company to host it, and I found that I can't get bukkit up and running, so what do I do in the way of a server?
Update: I found BuiildTools now installing
i run a minecraft server with a crappy old pc with a core 2 quad core and 8gb ram. slap ubuntu or ubuntu server and it flies. esp with your low amount of players
This guy.. Plus 1 that's all you need for a forum this size lol
Anyways @omega_alpha_psi run the build tools.. And always keep the old jars incase you need to roll back
That site is illegal, distributing CraftBukkit and its derivatives - I would recommend against using it. Go ahead and use BuildTools, but really if you're going down the Bukkit path - use Paper don't need to use BuildTools with their toolkit.
But I would recommend running SpongeVanilla (or SpongeForge if you plan on mods). Sponge Site
I apologise i did not realise it was illegal ill remove my comment. I personally do use buildtools i was trying to simplify things.
