Minecraft problems, need help now
Ok. So like many others, I received Minecraft as a Christmas gift. I have correctly installed, and registered. I have one problem, though. The problem occurs almost everytime after about 10-15 Minutes of playing Minecraft. I get a random error screen for my brand-new Windows 8 Inspiron Desktop (that I also got for Christmas). It always says "Ran out of memory," or something along the those lines. It is usually followed by another pop-up window saying something about Minecraft crashing. I have no idea what to do, because it works perfectly fine on my Windows 7 Laptop. I would like some help if any can be given. Whats the problem?
I would REALLY appreciate the help.
This error usually happens (at least for me) because you're running an older version of Java. I kept getting those same error screens, updated my Java to the latest version, and everything went just fine after that. I haven't had a single issue since.
Thank you, I just have one more question...Which Java applications do I need to install besides Java itself?
All you have to install is Java, Minecraft will do the rest.
