So I’m looking to build my first pc and the number 1 game I want to play is MINECRAFT!!!!! I was thinking about the $550 dollar build on here and wandered if there where any tweaks I should do to get the most out of minecraft??
You don't need neither processor power nor an expensive graphics card, with around 300$ in the US you can get a lot. You don't need that 200$ i5 or similar, people get it because it's doing well in benchmarks and it's good for other tasks too. I reccomend getting an intel dual core (Pentium Dual Core G640 or i3 21xx) or the older AM3 quad cores.
ahh a minecraft build...buy a calculator...that'll work. no seriously though, a 550ti will run it easypeasy, maybe even lower might be fine. 4gigs ddr3, i3 processor should be just fine. 450watt psu. and a micro atx board...gigabyte has some 80 dollar B75 boards.
make sure you get a quad core i there is a big difference about 40 fps i know i have a quad core and a dual even thought the dual core has a 550ti wile the quad core has a 9800gt or some cheap vid card like that
ya, if your playing mindcraft you should just look at going with an A10 or A8(fm2) build http://pcpartpicker.com/p/skzi or if you have 500-600 go with a fx 6300 and a 7850 build (better upgrade options) http://pcpartpicker.com/p/skE9 you could go with the msi 970 board but no usb 3.0 front header. but you save like $40 tho if you going to upgrade when steamroller comes out you should go with an 990x board or get a 990fx board
