Can you actually buy/pre-order Milan-X anywhere yet?
5800X3D is supposedly coming end of April.
I know AMD had been making Milan-X for a while and supplying hyperscalers, but I’m not sure if they’re planned for any kind of retail workstation, or a retail server, yet. (Same as Sapphire Rapids I think)
Maybe Lenovo or Gigabyte will have something on day 1 of Milan-X air-quotes “availability” /air-quotes
On the other hand, the M1 Ultra and the i9-12900k on DDR5 are shipping, and don’t require “industry contacts”, NDAs, or other your-lawyers-talk-to-my-lawyers, or your team talk to my team with lawyers in the room taking notes kind of deals just so you can try them out.
I see 7773X with additional cache as a mitigation for epyc 7763 performance issues in two socket machines, that arise with some workloads due to 7763 having 128threads and only 256MB L3 and 8 ram channels per socket. (2MB L3 per thread/1channel for 16cores). Milan-X is a cheap way to get more performance mid cycle without having to go with DDR5, and without having to go to an all new platform in the middle of a chip shortage.
In terms of datacenter workloads, any workload where you might be hitting memory bandwidth issues would benefit, typically any workload that’s branchy where you have a O(hundreds of megabytes working set).
E.g. If you have soft-realtime web services and are leaving threads unused because of high tail latencies… this CPU is probably for you. Also, if you’d rather go with 75F3, but it’s cost prohibitive due to low density, maybe 7773X is a sweet spot.
When you benchmark your code, if you see diminishing performance per thread and reduced IPC due to ram congestion on 7763 when you add worker threads, maybe this CPU helps.
Also, if a few racks of 7763 make sense for you financially (e.g. not great for your workload core-per-core compared to 8280 , but cheap), then 7773X probably does as well … (assuming you can source it - NDAs and contacts and what not).
I’m also looking forwards to Sapphire Rapids with HBM… for same/similar type of workload as 7773X.
I don’t think something like hashcat would benefit much from extra cache on Milan-X. If it runs good on a GPU - trivially parallelizable, small working set code, it probably won’t see much benefit from extra cache.
