Hi,
I’ve got some P225p broadcom 2 port 25g nic’s on a Supermicro H12SSL-i motherboard.
The issue is on various OSes, even just in the BIOS the issues I’m having are present.
The issue is that some ports on the P225p will auto negotiate 25G with the switch, but then flap up and down and eventually mostly just stay down. They do not pass traffic. If I turn auto-negotiate off I can get it to link at 1G. The strange part is that if I move the DAC cable to a different port on the switch, it will link. And if I move to a different p225p port it may link on one of the previously non-working switchports.
I’ve got 2 p225p’s per server, 5 of these servers, and 4 of the CRS510-8XS-2XQ.
I’ve got the same settings applied to each of the p225p’s, and each of the Switches. There doesn’t seem to be a correlation to the issues occurring on a particular switch as when I swap the switch positions the problems will be present on a different switch.
I’ve got RDMA turned off on each of the network cards, and the settings are the same between the ports which are working and which aren’t working.
For context on how this will eventually be setup it’ll be 5 Ceph nodes with a separate frontend and backend networks (2x switches in each). With LACP setup on one port on each of the two network cards for the frontend and backend, and MLAG between the switches in the frontend, and same for the switches on the backend.
I’ve got traffic flowing across the MLAG but I’m finding it hard to move forward with such a strange issue that I can’t get some of the ports to link properly at 25G.
The DAC cables are all Mikrotik and I haven’t noticed a trend between any individual cable and these issues. The same cable and port (on either side) will successfully link, but there are specific combinations which just will not link up.
I’ve factory reset various parts and tried a lot of moving things around.
I’ve successfully written to the Ceph cluster at 1GB/s over this network (limited by the 10G connection on my workstation) so these issues aside I think the actual network config on the switches is approaching being correct.
It’s at my job and I’m finding this to be such a weird situation that no matter what the fix ends up being I think it’s going to be interesting and worth documenting it here. I’m in touch with some people for support but it’s the kind of thing that someone here may have come across something slightly related in the past and if not just writing it here might help someone in the future
