Mid-size case that can fit an EEb Motherboard?
Hello~
Just decided to poke around the forums and decided that it is a good place to ask this question- I need a not too flashy case to go in a college dorm...I would prefer it to be as small as possible while still handling the following needs...
Sorry if this is too nit-picky...I worry about cooling and don't want to purchase a case just to have it not fit...
I am building a PC similar to the one on the Tek Syndicate youtube channel
v=7Tyudcr1uLY
except going with dual used 8 cores...I can find some for an "okay" price...so I though "why not?"
--While I am only going to college as an illustrator, I am building this to render OTHER peoples stuff, the dorms are shared with even those going for 3D and I wil be rendering others stuff over the internet... I will be pairing it with a low end workstation card for the 10 bit output with an Asus ProArt monitor.
I need the case to fit dual H80i radiators up top so the fans can blow air down onto the mosfets, I saw a video where they got pretty damn warm with the higher core CPUs. --Is that the same as an H100i in width? or would that be too wide?
I also read the R4 can handle EEB boards even though it's only ATX, does that mean something like a tempest 410 Elite would also fit one? /That case has a lot of fan places...
The only things I would need from the case are:
Removable filters - I hate taking apart PCs for cleaning, it just takes forever when you start to jam it full of hardware.
Dual front fans - 120mm or 140mm fans will be fine, I worry about cooling and would be using AF LED quite fans in the front.
Mounts for 2 SSDs - Or support for SSDs in the 3.5" bays
Space for the coolers up top -
A side window would be a nice touch...The H80i blocks glow and that would look good (I want to make a PC the looks "pretty") Though this isn't necessary (The windows-less R4 is like a tux :'])
...I WOULD go with the R4 but I'm not sure it can actually fit EEB...I worry about cooling as well, It is a pretty clean case design but the acoustic trade-off may not be worth it...
The case can be gaming-esk but I don't want it to be flashy...the tempest 410 was pretty much at my limit...I don't need to be able to see the front fans or anything, I just want something that would be presentable as a work PC an not as a "hardcore" gaming one.
I'm sorry if this is a little...picky...I just want a case that isn't massive as I will be in a dorm...though I'm more worried about cooling and how clean it looks...I don't need the fancy window, it was just me being a nitpick...
thank you for your time.
