Hello All!
I'm looking to build my own PC. I will use it for standard Internet browsing, Adobe Photoshop and Adobe Lightroom. I want a solid PC with strong parts and even though someone could probably piece together a $250 machine, I would like to spend between $350 to $500 to get a decent machine that will last me a while. I was also thinking about building it around the AMD A10 or A8 processors. After much research I have found that building a mid range system is much more complicated than a high end gaming PC where you can basically go all out with everything! I would be very happy if some people could suggest some good builds or even just some good individual parts! There is a PcPartPicker link below with some loose ideas I've had..... However feel free to change any- and everything! Any suggestions as far as Motherboards, RAM, Case, or power supply go will be gladly accepted.
http://pcpartpicker.com/p/1L6hy
Thanks in advance!
Johannes
P.S. Feel free to ask any questions about things I may have left unclear.
It's a bit difficult with a $500 budget to get a nice rig. I'd go with a dedicated GPU, though. I'd also like to point out that there's no case :P.
http://pcpartpicker.com/p/1LiLD
CPU: AMD FX-6300 3.5GHz 6-Core Processor. 6 Cores will help with new games, and will help with photoshop and other productivity apps. Is a lot better than the 5800k/6800k
MOBO: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard. Couldn't find a decent ATX one that I could fit into the budget. This one has a bit of upgradeability and fits everything I wanted.
RAM: Kingston Blu Red Series 8GB (2 x 4GB) DDR3-1333 Memory. Cheapest 8GB kit. I prefer 1600mhz, but 1333 should do, as most of the load will be on the GPU during gaming and such.
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive. Typical 1TB drive
GPU: MSI Radeon HD 7850 2GB Video Card. I didn't want to skimp on this one. The 7850s are really good for the price.
CASE: Fractal Design Core 3000 ATX Mid Tower Case. Cheap case. It works.
PSU: EVGA 500W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply. 80+ Bronze. It'll work.
OD: Lite-On iHAS124-04 DVD/CD Writer. Cheap OD, if you need it.
