so ive been perusing the forums looking for ides on a budget build (cause im totally origional like that) theres no real difinitive budget (but Id like to keep it in the 700 - 800 range [which ive already broken]) Its mostly just for gaming and i hope to leave room to upgrade in the future. I got most of this build from a similar forum post but changed a few things mostly the case though. this is my first time building my own computer so any advice would be greatly appreciated.
CPU/Mobo - Intel core I5-3570K + ASUS P8Z77-V
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1033223
PSU - Antec BP 550 plus 550watt
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016&Tpk=antec%20BP550%20plus
RAM - Corsair Vengence 8Gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186&name=Desktop-Memory
GPU - MSI radeon HD 7950
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127667
HDD - Western Digital 500GB 7200RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Case - Zalman Z11
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235033
ODD - (insert any DVD burner here)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Cooling - Cooler Master Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
So I have a few real questions about the build...
1. Ive had cooling issues before is that cooling fan enough or should i get somthing else/more (I assume that the case comes with built in fans but I dont know if i need more)
2. I plan on upgrading at least to add a SSD, a bit more RAM if possible, and a BlueRay burner. is that power supply going to be enough or will i need to upgrade that as well
