Mid grade pc build
Ok so I hvae the following parts ; His 7870,
                                                    CX 600W,
                                                    500 GB HDD.
I want to upgrade my system how do you feel about the following parts:
Fractal Design R4,
Samsung 840 SSD - 120GB ( OS, and games )
MSI 970A-G46 Motherboard,
G.Skill 8GB (2x 4GB) Dual Channel Ares Series Memory Kit,
*Now The question is* 6300 OR 8350?
i may not be overclocking my cpu ( I will have the stock cooling for it )
What is your current setup, what is your budget, and what will you be using it for?
Current: 7870, FX4100, Gigabyte:M68MT-S2, 4gb ram 1333mhz, 600 W psu
i will spend £200 - £300 maybe a bit more. I play agmes at hig settings at 60 fps.
If you have the money you might as well just go for the 8350. It will be faster than the 6300
is it worth the £50 difference?
