Mics and Sound recorder recommendations for a broke filmmaker
Ok so I have a great camera (the Sony NEX-VG30) and it's working out great.  Problem is I need some mics and a sound recorder.  My parents are willing to pitch in for me to get some cool gear but nothing too expensive.
I need a good quality shotgun mic, a good sound recorder, and some lav mics.  I'm looking myself but I know asking the forum might come up with differing results than I might easily find.  My camera has a foot mount so the shotgun mic and lav mics need to come with a connector of some kind.  I spent plenty of time finding the right camera because I knew exactly what I needed but I'm not as well versed in buying mics and recorders and I'm just not so sure which ones sound the best at an appropriate price.
Any help would be appreciated.
Always post a budget man!
Oh haha, I'm looking for maybe a few hundred bucks.  Nothing over 500.
do you want a software based sound recorder? if so, I'd recommend Audacity. It is free
I'm not sure on lavs but for shotguns you could go with something like a Rode NTG2 or Audio Technica AT897. If you want to have a stand alone recorder something like the TASCAM DR40 or Zoom H4n would work. Wouldn't leave you much room for lavs but you would have a solid shotgun mic and recorder. You can always go cheaper with the shotgun mic too but mics are one of the few things that I think you really get what you pay for.
I need a hardware recorder for recording while on a shoot.  Not gonna carry a laptop around while filming on a street or something.  I need it primarily for lav mics since I can't exactly record three different mics directly into my camera.  Just trying to figure out some options.
Well instead of the shotgun mic you could get one of the recorders I mentioned a few lavs. You can actually use the recorders to record 2 separate channels as they have 2 condenser mics on the device. You can then plug 2 more mics into them for 4 channels of audio. I think the main expense is going to be whether or not you can use wired lavs or need wireless ones. You can find wired lavs for good prices but the wireless systems are always pretty expensive (for a good system that is).
