Microphone Too Sensitive
I'm am trying to record commentary, but my Microphone is picking up EVERYTHING around me (i.e. fish tank, mouse scrolling, and even my hand being lifted off the mouse). I've been trying to find something in Windows 7 that will allow me turn down the sensitivity, but alas I've had no luck. If anybody known of a way to help me fix this issue that's be awesome.
Thanks, Brandon.
make sure you've activated the right microphone. (you might have your laptop mic/ webcam mic recording instead of your other microphone.)
Go to your sound devices and adjust the recording volume of your mic
>start>sound>recording tab
Then look around the properties. If there is nothing in there to lower the sensitivity, then you might want to look in the recording software that you are using. Also, you might want to think about getting a different mic, one with a cardioid shape of pick-up.
