Microphone Stand
So I didn't really know where to put this, but I need a low profile mic stand that will sit on my desk.  I need one that will work with the mic that I just bought here -
http://www.amazon.com/gp/product/B00M6NEBD6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I know that it isn't the best mic, but its a start.
Looks pretty standard, so pretty much any desktop stand would work, like these:
http://www.amazon.com/PYLE-PRO-PMKSDT25-Adjustable-Desktop-Microphone/dp/B005MII5MK/
http://www.amazon.com/Bluecell-Microphone-Portable-Tripod-Desktop/dp/B005DJBYUS/
http://www.amazon.com/Hamilton-Nu-Era-Tabletop-Mic-Stand/dp/B003VYBD58/
or pretty much any microphone arm:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=microphone+arm
take your pick, they should all work fine...  though, the little desktop tripods might be a bit unstable if you use your shock mount.  Just a heads up.
Thanks I really didn't know if there was a standard mounting system with the microphone.  I think i'm going to have to go with the arm, idk why but I always thought that they were more expensive.
