I've been watching for Microboards on fleabay and not seeing much. Saw this one show up today.
Been focusing on the wasabi mango 49" but I do like the looks of the microboard.
Has anyone played with this? My googling hasn't found much for reviews.
HDMI UHD 30Hz, FHD 60Hz
DVI 2560 60Hz
Energy Saving 23w~60w
MHL (HDMI)
PBP / PIP
FLICKER FREE
Displayprot 1.2 UHD 60Hz
HDMI 2.0 (HDCP2.2) UHD 60Hz
HDMI 1.4, RGB
USB Firmware Upgrade Port
Speaker 10W x 10W (20W)
TV style remote controller
Low Bluelight
Audio Out
Chroma Sampling RGB 4:4:4 Support
Specification
Resolution : 3840 x 2160 @ 60Hz
Size : 49" 16:9 WIDE(123Cm)
Panel : LG AH-IPS LED backlight, COLOR 72%
Pixel Pitch : 0.27963mm x 0.27963mm
Color representation : 10bit, 1.06Billion colors
Maximum brightness : 400cd LED BACKLIGHT
Contrast Ratio : 1,200 : 1(static contrast) , Dynamic Contrast Ratio: 50,000 : 1
Viewing angle: 178 degrees left and right, up and down 178 degrees
Input Terminal : DP 1.2 x 1, HDMI 2.0 x 1, HDMI 1.4 x 1, HDMI - MHL,RGB
VESA mount : 100x100, 200x100 support
