Micro ATX/ITX System for Uni!
Hey forum, I will be going to university in a week and decided that I would like to build an Micro ATX/ITX system to take back home and back to uni when I am on break. This will be used for gaming, not massively heavy but enough to play most games on high to ultra.
My main idea is that when I come back from uni I will take out my graphics card, Ram, SSDs and HDD from my current system which will stay at uni and put it into a Micro ATX/ITX system for better mobility. My current GPU is this:
http://www.amazon.co.uk/HIS-Turbo-GDDR5-2048MB-2xMini/dp/B007JRGUA6/ref=sr_1_4?s=computers&ie=UTF8&qid=1379347015&sr=1-4&keywords=his+radeon+7870
It is a fairly big GPU so I hope there is a big enough but also small enough Micro ATX/ITX case for it. I was hoping the forum could come up with some suggestions for the processor, Mobo and case for this system although I do like the look of:
http://www.amazon.co.uk/BitFenix-Co-Ltd-BFC-PRO-300-KKXSK-RP-%25200b%25200bProdigy/dp/B008BZVTX8/ref=sr_1_2?ie=UTF8&qid=1379346842&sr=8-2&keywords=itx+case
I have around £450 to spend but wouldn't mind spending less or more!
Any suggestions would be greatly appreciated, thanks!
This is something i recommend, the Asus maximus impact is one of the best mini-itx boards to get at the moment.
http://uk.pcpartpicker.com/p/1tftg
or this: http://uk.pcpartpicker.com/p/1B1Y1
only you need to add an aftermarket cooler on it.
Would you always advise doing Intel CPU on this sort of build? If so, why?
well simply, because there arent any AMD AM3+ mini itx boards. thats why you have to stick with intel ☺
Thank you very much. Very helpful information, exactly what I needed!
Final quick question, will my AMD graphics card will work with an Intel CPU?
yes that will work absolutly fine. Radeon GPU on intel CPU or Nvidia GPU on AMD cpu, it doesnt matter at all ☺
Okay, thank you!
