Micro-Atx Case Search
Hello TekSyndicate forum!
I am looking for a Micro-atx case for a gaming rig that I will be building soon.  I was hoping you guys could suggest some good cases that fit my needs, because I am torn on what to get.  This will be an air cooled build so no need for radiator compatibility.  I will be taking this to college so I want it to be pretty portable and preferably quiet. My budget is anything under $200.  If you recommend a case, please explain why you like the case.
Requirements for the case:
- Micro-atx size   -   I don't want to go mini itx, and I want it to be pretty portable so no mid-tower/atx cases
- Good Quality   -   no cheap plastic cases or crappy cases
- Window   -   Must have window! I want to admire my work, and I'm not going to mod a window
- Room for two graphics cards
Thanks in advance!!
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811144161
enjoy
Not a fan of that style of case, and I might add a second graphics card to my system down the road and the 420w power supply will not be enough.
Thanks for the input though!
So we have:
1. The Corsair Obsidian 350D (a bit on the big side of mATX cases, but seriously sexy): http://www.corsair.com/us/pc-cases/obsidian-series-pc-case/obsidian-series-350d-windowed-micro-atx-pc-case.html
2. The Fractal Design Arc MINI (Not MIDI) R2 (just the right size): http://www.fractal-design.com/home/product/cases/arc-series/arc-mini-r2
Both of them great cases, and well below $200.
corsair obsidian 350D
antec vsk-3000E
