Mice HElP UK!
I am looking for a decent gaming mice. I'm on a tight budget of £30 so suggestions are much appreciated. Doesn't matter if its wired or wireless but if possible with blue LEDs and not too big.
Thanks,
Atobe
http://thewirecutter.com/reviews/best-gaming-mouse/
Thanks baufu but almost all of the mouse in that article are over my budget really.
http://www.amazon.co.uk/Logitech-G400s-Optical-Gaming-Mouse/dp/B00CJAEX70/
I think it's worth some extra.
Found this and would this fair with the Logitech one?? or the extra £4 gonna be worth it??i kinda like the looks on this one tho :) http://www.scan.co.uk/products/mionix-naos-3200-led-optical-gaming-mouse-with-customizable-colours-3200-dpi?utm_source=google+shopping&utm_medium=cpc&gclid=CKL43dqp3bwCFa-WtAodnkMAIQ
G400s has a better sensor, though you will probably not notice it.
I recommend getting G400s if you have big hands, as it allows for comfortable fingertip grip in this case. Otherwise, 3200 is fine.
