Metro Last Light woun't run!
Alright i just build my new pc and i have  270x  benchmarks say say i should be getting like 40fps on my settings is there something im missing some divers? Update? Some shit? If any of you know whats wrong plz help btw i had to post this fast sorry for gram
The game doesn't launch? Or are you not hitting the fps you want?
What cpu you using? And yes make sure to always download and install the latest drivers.
The game runs at like 14 fps low everything and i have an fx 8350 overclocked to 4.1 ghz
check in Options and turn off Advange Physics ,last light has an crappy cpu physics system that uses only one thread of 8 of yours since your use amd not nvidia (so no cuda physics)
will run like an beast after that :)
is there a wrong slot on the mother board for it?
Thx so much Uys88 i didn't see it in the setting but i found it so thank you i was woried i screwed up my pc
