Ok I just got metro last light today and I'm rockand a i7 3630qm, 8gb if ram and tow gtx 670I at the lowest possible settings and 800 by 600 I'm getting 15 fps and at I'm gettinattune same fps on almost all other settings and the nvida GeForce recommended settings. does anybody know what the problem is or waists going, leave the latest drivers. I away also able to run crysis at 1080p with the best aa and 16 at high settings, some were very high and I was getting 35 fps.
Also all my desktop icons are re arranging them selves.
Hmm... Metro LL is just a killer, perhaps.
lowest settings at 800 by 600 15 fps with my gpus and I ran crysis 3 at 1080p at almost max settings, It can't be that much Of a killer and when I turn settings up the fps doesn't lower. I am at the level where you save paveI, I'm in the aireduct right beside him and I'm getting 15 fps. It's a dark, no particles and a closed area, I shouldn't be getting such low fps especially at those settings.
http://www.notebookcheck.net/NVIDIA-GeForce-GTX-670M.72197.0.html
this is just one 670m I have two, so really what could the problem be. Is it the drivers maybe, are gpus somehow broken, is the CPU somehow bottle necking it so much.
I don't know if this is much of an answer, but according to Logan, it's not only you getting that poor amount of FPS.
http://www.youtube.com/watch?v=eu8Sekdb-IE
I'd go with brennan's answer on that one, seems to be the Crysis of 2013! (perhaps??)
I looked up some benchmarks for the gtx 670m and it said it got 17 fps on ultra settings with just one card I have two and I'm running at 800 by 600 lowest settings and im getting 15-10 fps they were running at 1920 by 1080, the GeForce experience recommends some settinsg and that runs at 15 fps. That's why I'm thinking it might be horrible optimization off sli or somethinLillie that, drivers issues or the hardware is broken.
Well damn I guess I won't be playing this gare then since I csnt find a solution.
try contacting the developers. you may be able to run a test they developed, send them the results and they can tell you the problem. This is what my friend did and his problem was fixed in not too much time.
also, mobile CPUs and GPUs, even at the top end, are soooo much weaker than desktop counterparts
disable one of ur GPUs ,and try ...
It was the stupid driver, the 320 driver, I reinstalled an old 315 driver and now the game works perfectly. Well as rich from reviewtechusa "oh the pains of pc gaming".
